Missing `My Club Vaio`
Philmike
Just completed a clean reinstall of my Vaio VGN-FE41Z with supplied disks (Vista), Then updated to Visa Ultimate via the internet. All apears to work well apart from I have lost `My Club Viao`. I have installed everthing from the Vaio web site all drivers and applications / softwear etc.
Anyone any ideas please,
Many Thanks,
Phil
4 REPLIES 4
kee-lo_
I wouldn't worry about it, it's not a vital program. Once you have registered your VAIO and use Club VAIO's website you really don't need it.
Philmike
Thanks for your reply, but I am concerned about missing updates to hardwear etc or will these come though Windows upadate?
kee-lo_
No, that comes through VAIO Update, which should be on your system tray
Thalamus.
Champion
Hi Philmike
You can also download Vaio updates manually from here ..
