Missing Things After System Recovery
a7med_360
Ive just run a system recovery, and someone once told me on this forum i should i have the vaio camera capture utility pre built with my laptop(vaio ar21s) he also said if its not there do a system recovery.
Today ive ran a system rocvery (for a different reason) and installed all the drivers applications utilities etc and still i dont have the Vaio camera capture utility...any reasons why? and how i can download it?
I also dont seem to have the system resource management indicator by the system clock....how can i get it back there?
23 REPLIES 23
MattWilson
Well having Norton doesn't protect you from everything. You could have as many firewalls and virus scanners as you like but the hackers and virus creaters will always find a flaw and will always get you. You probably have had virus' and spyware before just without knowing it because you antivirus said you didn't you believe. There is no such thing as perfect protection so alway use as many different programs as possible and check on a regular basis. The only way to truely know that you have no virus' is to recover your system and not use the internet but thats just not convienient. So you just have to live with the fact that the hacker and crackers always win.
Its not our fault but we have to make there lives as difficult as possible.
Thalamus.
Champion
Hi a7med_360,
Does this remove the files..?
a7med_360
thankss it did
Thalamus.
Champion
thankss it did
:cool: You're welcome a7med_360... :slight_smile:
