Hi all!
I have spent week to contact technical departmen and nobody come back to me yet. I am trying to figure out a way to solve my problem ... I need help...
I have a Vaio sony PCG-581M model which I've now reinstalled to Windows XP. Everything seems to work fine just EXCEPT could not connected to our router. And when I checked drivers I missing Wireless network drive.
Please can you provide link where can I download correct driver for my sony PCG-581M.
Your speedy response would be greatly appreciated, thank you.
Kind Regards
Solved! Go to Solution.
Hi marosh11,
The reference you are quoting is the chassis model from the underside of the notebook that can be shared by several models.
Have a look on the screen surround or above the keyboard for the model number - you may find that it is a PCG-Z1 series.
Given this information we will be able to point you in the right direction...
Rich
Hi marosh11,
Rich
Go to http://esupport.sony.com/US/p/select-system.pl?model_type_group_id=10 and select your model. Hope you will get some help from here.
_______________
Life is too serious to be taken seriously
@ KatherineYH,
Please stop linking people to a USA Support site. Unless you are sure that it is a USA model you are just wasting everyones time and testing the patience of those members that are actually here to try and help.
Thank you , Rich
I found it. The model is PCG-Z1RSP. Well, I went on support sony site (http://www.sony.co.uk/support/en) and downloaded all drivers.
However, after I installed all drivers I still missing one calls: MULTIMEDIA AUDIO CONTROLLER.. see below.
Could you advise me?
Regards
Marosh
Hi Marosh,
I take it that you have no sound? Did you install the UAA High Definition Audio Class driver prior to installing the audio driver (you will find this in the Audio folder)?
If this is not the problem can you let us know the Hardware ID of the Multimedia Audio Controller – right click the device and select Properties > Details tab > Hardware Ids (from drop down menu).
You could try running the Microsoft autofix for sound problems assuming that this is a sound problem...
http://support.microsoft.com/kb/888111
Rich
