I've only had my laptop about 3 month and now my sound had started to distort. Can anyone help? I hope it's not a hardware problem...Had to format the other week because a virus had messed up my computer files, about a week after is when it started to distort the sound when watching videos, playing music etc.
Hi Love4MusicUK,
A few things that you can try...
1 Check that there are no enhancements enabled. Right click the speaker icon in the system tray and select Sounds > on the playback tab select Speaker/HP and then click properties > on the enhancements tab check ‘Disable all sound effects’ and then apply.
2 Check Vaio Support for updated audio drivers.
3 Uninstall the device in Device Manager and then reboot and reinstall drivers.
4 If by any chance you have installed any third party audio software since the recovery then try uninstalling .
Hi Love4MusicUK,
If there is no distortion from the headphones then there is a fair chance that the problem is hardware related.
Unfortunately, in order to eliminate third party software as the cause, I have a feeling that support will ask you to do a further factory reset before accepting it for repair
Hardware related when it's only 4 month old?Not what i'd expect after paying 700 pound for a laptop. How do i go about getting it sent in for a repair?
I thought that maybe some settings for the audio are set too high?
That is of course a possibility, but if it is one speaker that is distorting the only alteration I can think of is balance.
Go to Control Panel > Sounds and click on the playback tab. Click on Speaker/HP and then Properties > Levels.
Under Audio Output click Balance. If left and right are set at the same level then I doubt that this is the cause of the problem.
You could always experiment with external speakers, but as you mention that this problem is not evident using headphones I doubt that it will be with external speakers either.How do i go about getting it sent in for a repair?
Click support at the top of this page and select Get in Touch.
Hi, I contacted Support and they repaired it for me. Very quickly too, thanks Sony!
Jay
http://love4musicuk.webs.com
That's good to hear Jay
Thanks for letting us know.
