My Vaio doesn't go to sleep/hibernate when closing the lid
profile.country.de_DE.title
sam_sal
I have a Vaio S serie, simply I cannot make it go to sleep or hibernate using the ''Closing the Lid'' Function.
I can manually, from start menu, put it to sleep or hibernate or shutdown it. So it goes normally to sleep and it hibernates!
I changed the options in the Power Managment in Control Panel, I tried to put it to sleep/hibernate/shutdown when closing the lid, but it didn't!
When I close the lid, it makes nothing!
:smileysad::smileycry:
4 REPLIES 4
rich912
Hi sam_sal,
Have you checked the setting for this in Vaio Control Center > Power Management > Settings for Behavior When Closing the LCD Screen Lid? Assuming of course your model has this option in Vaio Control Center...
Rich
Go n-éirí an bóthar leat
KatherineYH
I have the same problem, my Z won't go to sleep when I closed the lid (I've changed the configuration in the control panel.
_______________
Life is too serious to be taken seriously http://imagicon.info/cat/12-13/text-smiley.png
sam_sal
Thank you Rich for replying.
Of course I have checked every option before I posted this thread here.
I tried to change the option (when closing the lid) to hibernate or shut down, still nothing!
rich912
Hi sam_sal,
This is a strange one as the settings are correct and you are able to achieve sleep from the Start menu. It is almost as if it is acting as a desktop.
Are actions  showing in power plan for both on battery and plugged in?
If this has started happening very recently then a system restore to date when it was working is worth a try. If it cures the problem then it may point to a recent update as the cause.
Rich
