Help! Sony vaio pcg-61611x
profile.country.pt_PT.title
starnet00
Hello dear friends, I'm from Brazil, I come here requirir your help, I am now on my bench aSONY VAIO PCG-61611X than simply giving this very trabalho.Ele is not binding, moreenergy goes to the power input which is close the coils and transistor.Ele has no sign of burning or something in placa.O Notebook is a very new thing or two months of it thisuso.A source of voltage. What can be? I hope you help me, I thank you!
Tags (1)
rich912
Hi starnet00,
I suggest that you post your question in the Portuguese forum as the translator you have used makes no sense in English.
It would probably help if you quote the correct model number which is probably something like VPCEE43EB. You should find this on the lower right of the screen surround.
https://www.sony-europe.com/discussions/community/pt/assistencia?languageSelect=true
Rich
Go n-éirí an bóthar leat
