Need to reinstall windows 7 but don't have disc
JaneBlonde
I need to reinstall widows 7 64bit for VPCSA3M9E. I have everything except the disc but cannot find a place to download it.
What are my options?
Tags (1)
16 REPLIES 16
rich912
Hi JaneBlonde and welcome to the forum,
The recovery media is not available for free download, you need to purchase it - cost €35.00
http://eu.eetgroup.com/Guide/m/Sony-VAIO-VPC-models-VPCSA3M9E-XI?sortBy=Stock&asc=True&filter=recove...
Assuming that you have the original hard disk installed and the recovery partition is intact, have you tried pressing F10 at boot (when you see the Vaio logo to enter the HDD Recovery Utility?
Rich
Go n-éirí an bóthar leat
JaneBlonde
Thanks Rich.
A 32bit windows 7 has been installed over the original sony windows 64 bit sony. I don't see a partition disc at all. I do see an old.windows folder.
Would that be ok? Really I need to go back to factory defaults.
rich912
Hi JaneBlonde,
It doesn't matter which operating system has been installed, the Recovery Media will recover to factory defaults. Note that all personal data and third party software will be lost, so make a backup if needed. I assume that the hard drive has not been changed as there are possible complications if it has.
Rich
JaneBlonde
I've tried to buy Sony Recovery Pack 7PE64 UK EUAE590AG but my country Ireland is not listed there, is it a download or a disc? D
rich912
Hi JaneBlond,
As far as I know it is a physical disk. I notice that a lot of European countries are missing, including the UK.
I suggest that you use the 'County' entry for 'Ireland' as Country doesn't seem to be a required field or contact them for guidance.
https://eu.eetgroup.com/info/contact
Rich
JaneBlonde
Ordered, I'll let you know how I get on.
d
rich912
Good luck. Yes please let us know how you get on as I sure the question of missing countries will crop up again
Rich
JaneBlonde
I didn't get on well, since last posting I ordered and received the recovery pack, but it does nothing to install Windows again, all it really did was display errors from techie stuff to messages like this is not compatible etc. eventually the only option that worked was delete data.
So I guess I now have a shell of a vaio and still need a windows 7 disc to get it back working.
There are 12 discs with the recovery package, only the first seems to do anything and there's no instructions.
Have I missed something?
JaneBlonde
Anyone there?
