Today I had remote help with installing my Norton 360 and the chap in India 'locked' the numbers and I haven't been able to unlock them since. I now cannot type without nunbers being added into words and it is so frustrating.
Can you tell me how to switch it off please
Message was edited by: empscott
Hi empscott and welcome.
Have you tried pressing the "NumLk" key?
Yes, but it doesn't switch it off. Is there another way. It has never happened before
There is a possibility that the Norton support agent has disabled the Num Lk function within the registry.
Try the following:
1. Click Start, click Run (or search), and type regedit to open the Windows registry editor.
2. In the registry, navigate to HKEY_CURRENT_USER\Control Panel\Keyboard\
3. Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2.
Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
Rich
