help
slimslaney
help
can anyone help i have a sony vaio notebook vpcea3m1e but i dont know where to find the sony firmware extension parser can anyone help am useless with computers thank you
rich912
Hi slimslaney,
There would seem to be a server problem at present but, when working again, click the Support tab at the top of this page, then click on-line support. Enter your model number to access the support page. In the download section you need to look for SFEP driver.
This only normally needs to be installed if you have upgraded your OS with a retail copy of Windows. It will need to be installed from within Device Manager using the Have Disk method. If you need guidance on this then let us know.
Rich
Go n-éirí an bóthar leat
