Hello, I've a VPCF11S1E and Can't send files from it. The Bluetooth is enabled and apparently everything is ok except that now, when I select a file with the Bluetooth on, I never see the sub-menu that allows it to be sent...
Tanks for the help...
You need bluetooth hardware in order to actually use bluetooth. If you laptop has a bluetooth adapter (which i think the DV2000 does have, can't be too sure though) then windows by default can transfer files using bluetooth file transfer (in windows 7 and vista don't know about XP). Go to the device manager in the control panel to see if your laptop has bluetooth, it should show up as a bluetooth device or bluetooth radio.
If it does not work or shows up as an "unknown device" then you may need to reinstall the drivers
Copy/pasted from http://answers.yahoo.com/question/index?qid=20100106210534AAnPA5l
_______________
Life is too serious to be taken seriously
Message was edited by: rich912
Edited to provide link to copy/pasted answer from a 3 year old post on another forum.
