Network Issue for LA1
mufcpaul
Hi to all you techies,
I have an issue the arose over night, my wired network connection has stopped working.
The 'Marvell Yukon 88E8036 PCI-E Fast Ethernet Controller' has the latest driver as i installed it when the problem occured to see if that fixed it, it didnt.
The Device manager says the hardware is working correctly but their is no connection between my router and the computer. I havent installed or changed anything so that cant be the answer either.
Please help, I bet its really simple!!!
Paul
0 REPLIES 0
