New Hard Drive
leethepee
New Hard Drive
I have a FZ18M and had it for quite a while.
I want to update the HD now to a Western Digital Scorpio Blue WD5000BEVT 500GB 2.5" and I just wanted to check that this was cool? I know I have a Seagate at the moment but will buying a different brand cause a problem?
Lee
That should be OK Lee. Physical size looks OK.
The only thing you need to consider is power consumption. The FZ-Series run very hot and the last thing you need is more heat. Check the power consumption when reading/writing and just make sure there is not a big increase.
:slight_smile:
leethepee
Thanks for the update.
How can I check what the power consumption of the HD I have at the moment?
profile.country.en_IE.title
sonypass33
I have a VGN-FZ21S and upgraded to this WD hard drive and I get better battery like out of it since the upgrade. No noticable change in heat.
