Today when i turned my computer on i noticed that my speakers does not work. When i plugged in an external speaker it worked perfectly. What should i do now?:smileycry: any advice please
Sounds like you have had a cable come loose in your laptop.
If you are not under warranty I would have a look inside to see if the cables are all OK.
If you have a warranty then contact VAIO Link
Thnx but where exactly should i look?the warranty is about to end in a week
Under the speaker grill and on the motherboard.
thx hope it helps
By the way should i just remove the plastic cover or will i have to move the motherboard as well. This will also be a suitable time for cleaning the fans as well, as i have never opened the cover before as you can see
I have no idea as I haven't opened that VAIO either.
oh that will be even harder for me then. Hope i dont have to move the motherboard probably i wont be getting courageous enough:smileyconfused:
If you're not confident then don't. You have one week of warranty left then definately use it.
You never know they might give it a full once over.
Actually the problem is i dont trust these computer services in here. I am afraid that i will be waitin for months for nothin
