No Sound On BLU Ray Disc
rdkelly58
I have just got my New Vaio All in One. Eventually got a BLU Ray To Play but No Sound at all. Sound is working in all other Apps. Any Idea's :devil:
jumpsuit
Hi there and welcome to Club Vaio :slight_smile:
What model Vaio do you have?
Have you tried control panel ---> sound and then right clicking and testing the different
playback devices?
Try selecting a different one then opening the app you are using to play the blu ray.
(The app must be closed while changing devices)
Depending on what you are playing it with also check the sound options within the
application.
It may also be the app you are playing it with may need an update.
