- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
No sound on XL-301
Am I being thick here? There doesn't seem to be a search option within the forums. I have always accessed posts via google up to now howevewr this time I haven't found the answer...........
Anyway, Windows update recently screwed my Windows installer and IE. After much swearing and faffing I did a complete 'return to factory settings' restore on my XL-301. Windows (bless it) immediately did 77 critical updates and I now have no sound on TV or from windows. All of the test options within Control Panel/volume etc don't make a sound either. I have downloaded and installed the new driver for the sound (Sigma Tel) as per Sony support and that didn't help.
It's not on mute either 😉
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just a further thing to add - I am using composite cables and before I did the restore it was all working sound wise and I haven't changed any of the cables etc.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
What version of the Sigmatel driver do you have installed?
Did you install the Microsoft Hotfix Package KB937287 from Vaio-Link before installing SP1?
Have you installed SP1 and installed driver: -
Audio Driver (SigmaTel) SP1_Filter DT1.0A - 6.10.5379
Does the driver show as installed correctly in Device Manager under Sound Video and Game Controllers? If so try uninstalling and rebooting.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'd also like to know where the Search facility went on this forum, tried to find it yesterday. THanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
the search function was removed by Sony a while ago as it was broken, use the following link to view Blencogo's alternative suggestion in a similar thread: Is there a search facility on the forum ?
