this morning I was realy desperate when I found out that there was not comming any music out of my player.
I only heard my command beep, my sound level was on max and I saw on the display that the song was playing.
connecting the headphone directly to the VP was also not a solution, I had to reset my VP to get everything normal.
My batterylife is also not very good.
It dos not matter if I use it a lot or little, it is always empty at the end of the week.
I Had the same problem last week. It was only one time, but I had also to reset de Viao to find ...the sound again. The problem, I Think, It's that I have used my Viao at that time, just near an electric piano....maybe the static electricity ? Everything is OK 10 days latter....So!
j'ai eu le meme probléme un jour ,j'ai cru qu'il etait mort
