only 2048mb Ram in my AR41S
yeldar2097
Is there a reason why my AR41S can't be upgraded to more than 2GB of RAM. I'm guessing there is a simple reason but I've been told that all the motherboards in the AR series laptops are the same so I'm a tad confused
yeldar2097
Alternatively, is there a way I can change the amount of RAM my GPU is using as well as its own.
Thanks again
kee-lo_
LOL 2GB should be enough for most of your needs. If you need more check Crucial's website.
