Wireless problem in XP after Dual Boot
jumpsuit
Hi guys
I have just dual booted a VGC-LM1M for a chum (don't ask me why they wanted it doing LOL)
The main problem I have is the wireless connection. As this machine doesn't have a normal ethernet slot in it (incredible I know) the only way to connect to the net is wirelessly.
The wireless is working fine in Vista - just not XP. It detects wireless networks but just won't connect to them. I have looked for drivers which may assist but can't find any.
Any ideas?
Hi Jumpy,
I think it should have an ethernet socket under the back cover - under the DC-in jack there should be a modem jack and at the bottom, an ethernet socket.
I suspect there will be lots of things on this model that won't work with XP!
All I can suggest is to check who makes the wireless card (probably Intel PRO Wireless) by looking in C:\Windows\Drivers and looking for the readme or setup.inf file under the Wireless LAN folder to see if it mentions Intel. Or use the Intel® PRO/Wireless Network Connection ID Tool from here: -
http://www.intel.com/support/wireless/wlan/sb/cs-010623.htm
You can then try to install the appropriate XP PRO Wireless 802.11 b/g driver when running XP. It's a guess but I expect it will be Intel® PRO/Wireless Drivers-Only for Windows* XP Ver 11.5.0.32 from here: -
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&Inst=Yes&ProductID=1637&DwnldID=13000&strOSs=...
Good Luck Jumpy!! I'm not sure I would know where to start!!
:slight_frown:
I see the US models use the ATHEROS LAN-Express AS IEEE 802.11 Wireless LAN Driver. If you have this you may have to Google about for an XP Version.
I can only find this Czech site: -
http://www.atheros.cz/download.php?atheros=AR5006EG&system=1
:thinking:
EDIT: Rather than use the risky Czech download, try the Preinstalled VGC-LA1_Drivers download - the XP version will be in \\LA1_Drivers\Drivers\WirelessLAN\Setup.exe. This is probably your best source for various XP Drivers for the LM1 - Ethernet/TV/etc. etc.
:wink:
jumpsuit
Thanks Blencogo - downloading drivers now.
The problem I was getting was that it would attempt to connect after inputting the wireless key - but it was stuck on attempting to connect.
I booted into Vista - which the wireless was working fine on last night only to find that it won't connect either, but with an instant cannot connect message.
Dual boot is easy :slight_smile: Its just everything after that isn't LOL
I really wouldn't advise it :slight_smile:
I can't believe I didn't think to rip the back of the machine off lol
