- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Partitioning FE21S
My Vaio FE21S has the hard disk divided into two partitions, C and D. With only empty Sonic Stage and Sonic Mastering Studio folders stored on D. Can I use Partition Magic 8 to repartition these two partitions into one full size partition without losing the links to the Sonic folders (if I move them to C before repartitioning). Would the recovery partition be affected ??
Many thanks for anyones assistance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You can repartition to any size or number of partitions you want.If you just wish to have a C drive only,no problems.You can go into the Sonic settings and change the default folder yourself.You could do a system recovery and do the Partitioning from that when it asks you.It does give you the options.Then it will reinstall all your Apps to C anyway.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Many thanks. By the way - I am very happy with my FE21S and the support provided by Sony and these boards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That's great news
