Hi, I have a problem loading the bios update for win 2000.
I have downloaded the files and when I try to run them it comes up with : Open failed on Bios ROM image file, then it comes up with : Invalid command.com system haled!
Any ideas?
Have a look under the VAIo if there's a pinhole which you can put a pen in to rest your CMOS.
Normally if you get a Open failed on BIOS Image message then the original file may be corrupted and so to prevent destroying your flash area of the BIOS, the flashing tool will terminate.
What flash tool are you using?
WinPhlash for VAIO is the only officially supported Sony update utility provided by VAIO-Link for my K-series VAIO.
Can you still boot into Windows?
Either that or use a floppy, the only safe way to do it.
There are a couple of pin holes - When do I press it? With machine off, on or what?
The flash updater is PHlash2 downloaded from Vaio site for this model, but no instructions!!!
I haven't got a floppy drive either, so thats buggered!!!
Will try the pin hole when someone tells me how!
Not sure, check your manual, DEFINATELY do it when it is OFF.
Try redownloading both files again too.
Why do they not publish hash keys to check the file is complete?
I would think that the phlash2.exe file is intended to be run from a floppy drive.
Normally if it is intended for windows use the file is called "winphlash"
You will need the genuine Sony floppy drive listed as an accessory for your model. A generic one will not act as a boot device.
William
