Hi ... I'm trying to add a second/slave screen to my Vaio desktop. Unlike a PC there appears to be no video output 15 pin socket.
Does the Vaio support additional screen/monitor ?
Is there a 2-way monitor splitter or something I can use ?
Graham
Hi Graham,
Please check your Vaio model - I cannot find a model PCV-31M.
Is it an 'All-In-One' Vaio? If so it is probably a VGC-V3M and you are quoting a chassis type.
If so you have no way of exporting video, except by USB. These 'All-In-Ones' are only designed to input video to the big Vaio screen and you cannot use a second screen.
