PCV-RS322E problem:
davevaio
PCV-RS322E problem:
I recently pruchased the above desktop over the weekend but have come to find a problem. I brought the PC home and set it up and came to install my ADSL modem which installed succesfully. I then try to install my BTopenworld CD to configure my connection, which encounters a problem straight from opening but continues to load the installer. Now, the installer says my computer doesnt meet the software's minumum requirements?
The CD requires a PII 233MHz and shows my PC has 33MHz :thinking: It also says I have no disk space memory, RAM or recent USB connections :anguished: thus the reason it will not run.
IAnybody any ideas how I can solve the matter?
Kind regards,
David Bailey
kee-lo_
Try and get the settings from them so you can do it manually.
davevaio
yeah, I'm going to ring BT first thing tomorrow to see if they can.
I was just wondering if this would be a problem for future installation, games etc? I've put on photoshop, dreamweaver and office which are all fairly big programs and they've gone on no problem. Strange.
kee-lo_
Yep, it's mainly the way BT made their software, it needs Java and uses MS' redunt Virtual Machine, which is a real pain. If you do a backup of settings once it's all working with the Files and Settings Wizard, you'll never need to put them in again.
