Please Help me.I have a problem with my first Hard drive :(
CuteeJazz
Hi, :cool:
I wanted to restore my first hard drive but it doesn't work :angry:
I've restore the second part with the system of gestion.
But now after back up all my files on my new (second hard drive) I want to restore the first in NTFS for all part. I put the CD restore and I restarted the computer . The problem is that the CD rom is not reconized :cry: and I can't do anything :cry:
I have an other solution but it's risky :anguished:
Format the hard drive in the post of work :cry:
I don't want a solution like that because I have no back up to make it good.
If you have a solution please help me :smileyrolling_eyes:
Thank you for reply :cool:
15 REPLIES 15
kee-lo_
Go into safe mode, and uninstall the CD-ROM, restart the PC and see if you can see it again.
CuteeJazz
How can I do to go into the safe mode ?
kee-lo_
After you see SONY on the screen, press F8
CuteeJazz
Thank you Kee-Lo :smileygrin: I'll try this :slight_smile:
And I will be back to inform you :cool:
CuteeJazz
I've just restore in a lower date .
Now I will try if I can to make the first part in NTFS with the CD rom of restoration.
kee-lo_
Good news :cool:
CuteeJazz
I'm still in FAT 32 :cry: for the OS part .
I changed the size of the partition but it doesn't change the format :anguished:
kee-lo_
No it doesn't
Isn't there an NTFS converter?
(Make sure you backup first)
CuteeJazz
How can I do back up ? :thinking:
Witch files I save?
