hello
Yesurday my Vaio Notebook packed in. The Screen was incredibly dark, so i shut it down. Now it won't even turn on!!!!
if anyone can help me then please please do!!!
Thankyou x
frosty987
Welcome to the club,
If you can get it to a monitor plug it in and do a system restore and run an anti virus. If it is a bad sector issue then get to the prompt or run in the start menu and type in CHKDSK. Also try booting off the battery. Hope it's not stuffed. Good luck.
Thanks for the help, but the thing is completely dead.
There a light on the charger which would suggest it's not a power problem, but I can't hear any noise coming from it all.
Any other ideas?
Hi Frosty
Resit the memory if you're able to do this yourself. You'll find the instructions in the manual (oh damn just realised it's probably a PDF, nuts!)
Which VAIO is it BTW?
Hey
it Worked!!!!
Thankyou so much, i just took the memory out and put it back in. you've probably saved me alot of money.
thanks again
ben frost
p.s. sorry i was slow to reply, my internets not working either lol
No problem Ben, glad I could help you.
What's wrong with your internet?
