- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Please help, vaio won't shut down when power cord is plugged in
Hi, my vaio is only one week old, and already seems to have a fault. I can't shut it down while the power cord is plugged in, it just restarts, has any one ever come across this before, if so can it be fixed without having to send laptop away.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi rawrichie and welcome to Club Vaio.
Sounds like your Power Management needs checking!
Can you let us know: -
What Model Vaio?
Which Operating System?
Hopefully we can fix it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks, the moddle is vgn-fe31h and the os is xp media 05, hope you can help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi - sorry to take so long getting back to you.
Your problem is a common one and is usually caused by a program or process not shutting down successfully.
There are many things you can try - have a look at this Microsofr Knowledgebase Page
You may also get some ideas from this Very Long Thread on another Forum
It is usually a trial and error exercise to find the culprit - Just try these three things first and let us know how you get on -
1. Close down Norton Internet Security manually and then try to shut down.
2. Close Media Centre manually before trying to shut down.
3. Run a full Anti-Virus and a full Anti-Spyware scan - just to be sure.
