please help
paulsharp
please help
I hope someone can give me a bit of help here.
I bought an RS-702 about 6 months ago. It has a 20 gig c: drive and a 120 gig d: drive. Whenever I save any pics or music or whatever it defaults to documents and settings in my c: drive which is now full. Is there an easy way to change my default to the d: drive instead of having to go into file then save as?
7 REPLIES 7
rich912
Welcome to Club Vaio paulsharp.
I suggest that you move the My Documents folder to the D drive.
To do this, in explorer, right click in the My Documents folder and select Properties. Click on Move, in the next pane cluck on the + next to My Computer, single left click on the D drive to select it and click OK.
This will free up space on your C drive and also avoid grief if you ever need to recover your system as the D drive us unaffected by a restore.
Anything that you save to My Pictures, My Music etc., etc. will automatically be saved to the correct folder on the D drive.
Go n-éirí an bóthar leat
VAIOFAN
Hi paulsharp, welcome to VAIO forum.
Yeah i have the same model as you, but mine is 502.
i have a 160GB hard disc and 30 on C: drive and 130GB on 😧 drive.
Do what Rich said because thats what i done.
I only use 30 GB for my programs i use everyday life.
but my work is on 😧 drive!
Ok mate, good luck
Paul
paulsharp
Cheers guys.
Have moved My Documents now to d and it looks fine, my only other issue is the My Pictures file is in Documents and Settings but I cannot move this file as I keep getting a warning that it is in use!!! Any more ideas??
rich912
Close any programmes that may be using that folder, including your desktop ( change your desktop picture if it is in that folder) and try again.
VAIOFAN
I mad that mirstake once! lol!
Got it now.
Paul
paulsharp
Nice one chaps. Thanks a lot.
rich912
:cool:
