PMB and iPhone4
tomp123
PMB and iPhone4
I've recenty got one of the new S Series vaio's which came with Picture Motion Browser already installed. When I plug in my iPhone though and try to import photos, the PMB software does not recognise the iPhone as a source device.
Can i do something so that it does recognise it? Or is PMB only designed to work with sony cameras?
No - but the iPhone is designed to work only with iTunes!!!
When you sync your iPhone you will see a Tab for Photos where you can nominate a folder on your PC to transfer and sync pictures with.  Put the pictures you want on your iPhone into this folder and sync the iPhone to transfer the pictures.
:wink:
