Power LED on a VAIO VPCY21S1E/SI
profile.country.fr_BE.title
vinbiche
Hello everybody,
I have a VAIO "VPCY21S1E/SI which features a very annoying power LED located on the right top end of the keyboard.
This LED turns orange and blinks when the thing is idling.
Anyway either to dim down the thing  or to turn it off altogether?
Thanks in advance for your help.
Vincent
rich912
Hi Vincent,
There is no software solution to your problem so if it is that much of an annoyance you will need to consult an electronics engineer.
Rich
Go n-éirí an bóthar leat
rich912
Hi Vincent,
Rich
vinbiche
Thanks a lot Rich! I guess I'll cut the damn cable out....
Have a great day!
Vincent
rich912
Or resort to some neatly cut insulating tape over the light?
Rich
