Probelm Pairing SRS-BT100 Bluetooth Speaker
Scrammbled
I have recently purchased a Sony SRS-BT100 Speaker and managed to pair it with my laptop no problem. However, although it says it's connected it does not play the sound!! I am using i-Tunes and can't see any reason why it's not working. Does anyone have any ideas as I can bluetooth to my Dell speakers and they work first time, everytime? I would of thought Sony to Sony wouldn't have been a problem!! Cheers
KingJim79
Try right clicking on the speaker symbol in the bottom right hand corner of the screen, select playback devices and then select Bluetooth Speakers as default device. My speakers started to working brilliantly after this, but now, over night they will no longer even connect...
It is frustrating that you cannot auto-connect to them and have to go through this process every time you want to use them.
If anyone can suggest how to get my speakers to connect now please help!!!
