Problem after windows vista express upgrade
tommythorpe
I have a problem with my fe31m after windows vista express upgrade.
The notebook doesn't turn off after the installation. Could you help me ?
Thomas
MichaelKnight
By default, Vista doesn't power off the system. If you stop the cursor over the power off icon, you can see (in the tip) that you will suspend (or hibernate) the system.
There is a expand button to the right that has extended options (restart, power off...)
Try it
tommythorpe
I'm italian and i don't speek english well but i understand you. The notebook doesn't turn off after i pressed the power off or restart. On the display there is "disconnecting" and doesn' turn off. With hibernate the notebook go well. Turn off and restart. To turn off i reset the notebbok. When restart vista windows permit to use normal vista or prompt comand or.......... and with this version turn off
THANKS
