Problems with vista on VAIO VGN-FE11S
juzaz
Hello
I have installed viista on my FE11S and i have installed the bios that fixes the screen bug when i close my laptop.
I have donwloaded and installed the update and drivers on sony website but i still have some problems:
- my memorystick drive isn't recognized, i don't see it and can't use it
- I can't use S1 & S2 buttons
- I have noticed that the file transfer from an externel hard drive to my notebook hard drive is slower than with xp
Thanks for your help if you have some information
Thalamus.
Champion
Hi juzaz,
Did you install the Drivers & Utilities from here ..?
juzaz
hello
thanks for your answer
Yes I did but I just realised that if It is needed to install the drivers that are the same that for xp, I don't have them.
I have seen on another post that i had to install "SONYNC", i have downloaded it but i don't what to do with the files in the archive.
