processor upgrade in a pcv rx202
does anybody know if i can upgrade my 1.8 ghz p4 processor to like a 2.4ghz processor in the sony pcv rx202 ? i been trying to find it on the sony site but i cant seem to find any info on how far the mainboard goes (processor wise)
i hope someone can give me some info about this.
thanks,
Joop
7 REPLIES 7
kee-lo_
As long as your CPU is the same socket size and the motherboard can handle upto 2.4Ghz then you should be fine.
Hi, thanks for ur quick response, but this i kinda knew already, what i kinda wanted to know is if the rx202 mainboard supports the 2.4 gig processor, i know its a 400 mhz fsb but i cant find the max speed i can put in the mainboard. Hope someone can help me with this question too
kee-lo_
Ah, that's something I don't know.
You'd have to ask over at vaiovillage.com
someone there is bound to know.
thanks :slight_smile: im going there :slight_smile:
kee-lo_
np, shame I wasn't more use :tongue:
fairdinkum
I'm also interested in upgrading my processor to 2.4GHz in my RX 202.
Anyone had any luck?
Des.
kee-lo_
Hopefuly the original poster will give you a few hints. Otherwise VAIO Village is a good place to ask, as there are a lot of "modders" over there.
