Programmes with foreign titles preinstalled on my Vaio?
MissDisgruntled
Can anyone help?
Whilst looking in the list of programmes which had been installed on my shiny new Vaio, I noticed amongst them the following (highlighted):
Should I be concerned that there are programmes with names in a foreign language on my UK laptop? It just doesn't seem right  that I don't know what they're for - or doing :thinking:
Any insight gratefully received
Sue
rich912
Hi MissDisgruntled,
As these are all Live Mesh ActiveX I think you will find that this is connected with the MUI of Windows Live Essentials which allows multi language change across the suite via Control Panel. Useful if you do need to change language as it includes spell checker for a number of languages – otherwise of no use.
You can uninstall the foreign language versions but as they take up very little space I would leave as is.
Rich
Go n-éirí an bóthar leat
rich912
Hi MissDisgruntled,
Rich
MissDisgruntled
Many thanks Rich
rich912
You’re welcome Sue:smileyhappy:
