- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hey, I have a Sony Vaio VPCEH3N6E I want to upgrade my laptop from 4gb ram to 6 or 8gb ram, was just wondering what type card I need to buy for it. Also since im in my gaurantee period does sony centers do this upgrading free for me if i buy the card and give it to them. Thanks
Cheers.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi cherianac,
The maximum supported RAM for your model is 8GB.
From the specifications for your model:
Memory Size (GB)
4
Memory Type
PC3-10600
Memory Specification
DDR3 SDRAM
Memory Speed (MHz)
1333
Memory Composition
4 GB (SO-DIMM) x 1
Max. Supported Memory
8 GB
This will not be fitted free of charge but as long as you follow the usual guidelines for avoiding static discharge whilst installing memory you should have no problems. If in doubt have a competent repairer carry out the RAM upgrade.
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi cherianac,
Memory Size (GB)
4
Memory Type
PC3-10600
DDR3 SDRAM
Memory Speed (MHz)
1333
Memory Composition
4 GB (SO-DIMM) x 1
8 GB
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thankyou very much for the quick reply, I also want to know how many memory slots this laptop has. Currently I have a 4gb ram. Does that rest on one slot or are there 2 slots in this PC?..As in if I want to make it an 8gb ram can I just buy one more 4gb ram ? Or does it have to be a single 8gb ram?
Message was edited by: cherianac
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi cherianac,
Your machine has two memory slots and the chances are that only one slot is occupied by the current 4GB of memory.
If you use the Crucial memory scanner it will tell you what is fitted and make recommendations for upgrading.
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Right ..thanks.
