- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I just got a vaio s series SA model
Ive found the right ram on cruical but there are two identical chips. Only difference being the voltages
one is 1.5V and the other is 1.35V. both the same price. what one do i chose?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi maccamuz,
Have you run the system scanner tool to find the recommendation for your model?
http://www.crucial.com/uk/store/drammemory.aspx
If that doesn’t prove conclusive then either give them a call or email your query.
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi maccamuz,
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Let Crucial check your system. They should know the answer to that and would surely recommend what is the best RAM for your unit.
