Hallo everyone! Just ordered 2g of ram from crucial. My vaio has 1g 533mhz will there be a problem if the 2 new blocks are 667mhz?
Hi duralex,
yes the memory should be fine as it is backward-compatible, what model Vaio do you have.?
Hi Thalamus!
I have a VGN-N31M
Hi duralex
Crucial actually recommend a DDR2 PC2-5300 DDR2-667 model for the N21M so this would also be the same for the N31M..
That's what I bought.
Thanks again Thalamus
You're welcome..
Not sure if you'll need this but here is a guide on how to upgrade your Vaio's memory.
Thank you. Just wainting for UPS to deliver it (to Portugal). Hope it gets here soon! :smileygrin:
It's here, it's in the computer, it's runing smooth anda fast. Plus it's alot cheaper than buing from sony, and gess what, they use ram from samsung
Glad your happy with the new RAM..
