hello
i have a sony vaio laptop that i bought almost 2 years ago. For some reason however the battery lasts about half an hour, i can literally watch the percentage go down. I 've tried a new battery but that isn't the problem does anyone know what the problem might be?
thanks, frosty987
maybe they need charging more (also take it off when using it on the mains as this will take life time away )
the best thing to do is but the power settings on optimized if 1 is better on the list choose that
if the problem carrys on contact sony direct as it may be a fault
