Recovery Media ignored
phgodfr01
I have just taken delivery of a Vaio SVS1313C5E which was preinstalled with Windoes 8 (much to my disappointment). I have followed the instructions and created the Recovery Media (6 DVD discs). I thought it prudent to check that the discs were working but find that the machine does not boot from the DVD. I also installed Acronis True Image for making backups and created a boot disc (CD) for that. The machine will not boot from that either. How do I get it to boot from the CD drive?  Both DVDs and CDs can be read fine, they just won't boot.
Thanks Phil
rich912
Hi Phil,
I don't have a machine running Win 8 but I believe you need to press the Assist button when fully shut down and then, on the screen that opens, press F11 to boot from media.
Rich
Go n-éirí an bóthar leat
rich912
Hi Phil,
Rich
phgodfr01
Thanks Rich, you are correct. Pity it doesn't say that in the setup instructions!
Cheers,  Phil
rich912
You're welcome Phil.
Rich
