Reinstallation of Windows XP
claudius
My HDD died and I have had to install Win XP on the new HDD.  When windows loads all I get is a small box in the middle of the screen.  How do I fix this?
It sounds like you have not installed a Graphics Driver!
If you install a clean version of XP, you must reinstall all the drivers and Sony Utilities if you want your Vaio to work properly.
These are available on the Sony Support site.
http://support.vaio.sony.eu/computing/vaio/index.aspx?m=0&l=en_GB
It is always useful to give your Vaio model when asking a question because we can then post a link to the correct page for your model.
:thinking:
