Replacement Battery
colinmann
Replacement Battery
Hello,
I have a FE21M - it's approaching 3 years old. Although I work within the computing profession I haven't upgraded as this thing does what I need it to do.
However, my battery isn't what it was. I'm now lucky to get 10 minutes out of it... so I want another battery. I've noticed on ebay you can get some really cheap ones - sure they are not Sony - but is this really the end of the world? Has anyone bad examples of this? Sony want to charge around £140 for a new battery - roughly £120 more than I can get it on ebay.
I'm looking for some advice please 😉
Regards,
Colin
Hi Colin,
I know Sony are expensive but you do seem to get what you pay for.
The problem seems to be that many of these batteries are not compatible and it is difficult to get your money back!
I remember several problems - if anyone has a good experience, please post it here.
:thinking:
