Restore to 'as new', from hidden partition?
Pe2dave
All in one, VPCJ21L7EB.
As delivered 17Gb partitioned off, I thought to hold a 'restore' point, from new?
Yet examining the disk this partition is empty?
Should the user 'load it'?
Anyone experience with this?
Is it a waste of space, i.e. create Windows backup disks as per usual?
TIA Dave
Tags (1)
Thalamus.
Champion
Pe2dave wrote:
How might making another set of recovery disks help?
I thought it may help to alleviate your concerns that the recovery partition was empty - When creating a set of recovery disc's the data is gathered from the hidden HDD recovery partition..
Pe2dave wrote:
Not having used the recover, is it possible to select what is 'recovered'?
I thought it was an all or nothing, revert to the bare setup when the machine was built?
There are a couple of options, obviously if you still have the original OS installed on your Vaio -
You can reinstall some but not all of the pre-installed applications should you need to using Reinstall Applications & Drivers option..
You can also Create a set of recovery disc's or Recover your Computer..
If you look at point 6 of the How to recover your VAIO with VAIO Care guide you will see an image of the choices I mention above, the guide is available using the following link - How to recover your VAIO with VAIO Care
10 REPLIES 10
Hi Pe2dave and welcome.
The Recovery Partition is a 'hidden' partition and you cannot explore the contents.  It contains the software to recover your Vaio back to Factory Settings.  Don't do anything that may corrupt this partition.
I would recommend you keep this partition as it may prove invaluable and does not take much space on the latest large hard drives.  Home burnt DVDs can become corrupt over time.
Yes, you should also make a set of Recovery Discs using Vaio Care - these will allow you to reinatall the system if you have a hard drive failure which means you cannot use the Recovery Partition to reinstall the software on a new drive.
:wink:
Pe2dave
Then why does it show as 17Gb 'unused', if it is used, for the recovery software?
How big is it? What is 'normally' used for (my case) win7 64bit.
How can I tell if it is truly empty or not?
Viewed using disk manager, not explorer btw.
I'm concerned in case I need it some time 🙂
DaveP
Have you tried making a set of Recovery Discs?  This will only work if the Recovery Partition is OK.
Can you post a screenshot of the Disc Management window from the Computer Management console? Does it have a drive letter?   It may be something completely different - like reserved for the Quick Web Access function.
:thinking:
Pe2dave
I have made a set of disks, np.
I'd like to have the security of what sony provide... if they have provided anything?
How to check?
Pe2dave
Screenshot attached.
'Healthy' recovery partition?
Empty recovery partition?
Which?  I can't tell.
Thalamus.
Champion
H Pe2dave,
as far as I am aware the EISA recovery partition usually states the same value for Capacity &Free Space, this is because the NTFS file system does not recognise the hidden partitions contents, this was the same on Vista Vaio models..
For peace of mind & a simple way to check if the recovery partition is still intact, try creating another set of recovery disc's or try to re-install an application or driver..:smileywink:
To do this open the all Programs menu, click on Vaio Care folder and then click Vaio Care..
Pe2dave
Thanks Thalamus... sort of makes sense (but isn't really logical, is it!)
"For peace of mind that the recovery partition is still intact you could try creating another set of recovery disc's or try to re-install an application or driver."
DaveP
Thalamus.
Champion
Pe2dave
OK, I'll give it a try.  Just so long as I'm given the 'back out' option!
It seems as if the recover at least will tell me the state of the recovery partition.
Thanks for the pointers.
Dave
