RX 417
Bluetiger
RX 417
Hello,
does somebody else has this computer ?
1. What's your opinion ?
2. What is negative ?
3. How fast burns the DVD-R burner CD-R's?
4. For what are you using this Computer?
5. Have you copied a DVD? If yes, what is your opinion?
6. Where are you from
My answers are:
1. I like this PC very much. :cool: But it isn't enough DDR-Ram in it :slight_frown:
2. Not enough DDR-Ram. Not enough place for a second burner or a second HDD.
3. ?
4. Games, Photos, Internet, Homework and perhaps in next year DV.
5. No
6. Cologne (Germany)
Bye Paul :smileyrolling_eyes:
P.s.: Sorry for my bad english :smileyblush:
Sleeper
Hi Bluetiger.
I like the computer very much but it has a number of problems:
1. Ram way too low, I upgraded to 512 MB. Furtunately, there seems to be even a third slot available.
2 CD-R and RW work well and fast (up to 10x)
3 DVD-RW is very slow. Apparently there is an upgrade possibility to allow 2x burning.
4. Yes, you can add a 2nd HDD.
5. The CPU fan is very noisy. I want to replace it but it has an unusual measurement.
Best regards,
Sleeper
