windows xp......
smsmasters
windows xp......
just a thought, if my hard disk breaks down (touch wood) if i replace how can reinstall the operating system. my has windows xp home and comes with recovery disks. can i use these disks to reinstall the os?? :anguished: :anguished:
4 REPLIES 4
EzDoezIt
Yes, the System Recovery discs include the Operating System.
The Application Recovery discs contain the software and the Driver Recovery disc conatins the drivers.
smsmasters
yay i now have 512 mb ddr ram. added 256 more yay, windows xp is faster :slight_smile:
smsmasters
but if my hard drive breaks down (touch wood) and i replace it with a new one. do i need to format it first or will the recovery discs do it all for me?? i dont to buy windows xp home! :anguished:
robpaxton
Your recovery disks should handle all that for you.
Regards, Rob
