S5XP - no Windows CD supplied?
bb67
Just got an S5XP and there was no Windows CD included in the package. Is this normal, if yes what's the process if I need to reinstall at some time in the future?
My previous Vaio has had Windows reinstalled from the supplied CD a couple of times over the years.
MTIA
10 REPLIES 10
S5VPspecial
You do not need any CD Software as it is all pre-loaded on your PC including the setup files. If you need to re-install, just go to your recovery tool and pick the earliest restore point. Your computer will revert back to the way it was before it came out of the box.
