Saving e-mails on Vaio VGN N21MW
CarlMichaelJwtt
I have a small problem. when I try to save a e-mail from AOL to my laptop I canot find it on my lap toptop although I am told it has been saved in my personal folder I just can not find this in my documents, even when I try to find through search facility, has any one any suggestions. Regards Carl
5 REPLIES 5
Thalamus.
Champion
Hi Carl,
I don't use AOL but I'll try to help..
Are you viewing your email online or are you using an email program on your PC.?
How are you trying to save the email to your PC.?
Or does anything in here help: How do I save e-mail to my Personal Filing Cabinet?
It will depend on which version of AOL you are using but it is typically in the folder:-
C:\Documents and Settings\All Users\Application Data\AOL\C_AOL 9.0 VR\organize
The emails will be stored under each Screenname in the file with no extension.
Unfortunately AOL PFC uses strange formats - I have not tried to convert the files and address book but there is some software designed to convert AOL PFC files to other formats: -
http://www.connectedsw.com/Overview/57266
:wink:
Sorry Carl - I didn't realise you were talking about your NW21 Vista Vaio. The location above is for XP, for Vista try here: -
C:\ProgramData\AOL\C_AOL 9.0\organize
:wink:
CarlMichaelJwtt
Thalamus very many thanks for your help,still trying to sort out. Carl
CarlMichaelJwtt
Blencogo trying to sort using your suggested links many thanks Carl
