SD card support - Sony VAIO VPCZ12X9E
profile.country.el_GR.title
pbakop
Hello,
I have a Sony VAIO VPCZ12X9E and, according to the manual, back in 2010 it was certified for SDHC memory cards with capacity up to 32 GB. Does anyone know if my VAIO will be able to work with SDHC or SDXC cards with 64GB capacity?
Thank you very much!
Paraskevas
profile.country.en_IE.title
lurchbt73
Hi pbakop. One option you could try is by using a usb memory card reader.hope this helps
