SD/MCC slot
JLuigi
SD/MCC slot
I have a VAIO LA-2 series with Vista Home Premium 32bit,
for sometime I have been unable to load any of my SDHC cards on the SD/MCC slot, it just will not read them – any suggestions?
7 REPLIES 7
Have you ever been able to load SDHC cards?
On most Vaios the SD slot does not support SDHC.
:thinking:
slimest
Нет проблем со слотами. Все работает мухой. Посмотрите, установлены ли у вас корректные драйвера на кардридеры. Смотрим в: Правой кнопкой по My Computer - Properties - Device Manager.
Added: sorry, mistakenly answered in Russian. Now in Enflish:
No problems with cardreader at all. Everything works. Try to check if all drivers are installed: My Computer (right button) - Properties - Device Manager.
JLuigi
yes over a year ago I could use the SD/MCC slot to read SDHC cards then all of a sudden it stopped.
If it once worked I would try reinstalling the original memory card drivers.
You may find this in a folder C:\Drivers on your hard drive or you can download the Original Drivers Package from the support page for your model here:
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGC-LA2
slimest is giving excellent information - thank you.
:slight_smile:
JLuigi
Thank you for you reply.
I have checked the drivers but they all look up-to-date, any further suggestion?
Regards
JL
Even if the drivers look up to date, I would still try to reinstall the original one. Often a Microsoft Update can make changes to drivers.
If that does not work you will have to buy a cheap external USB card adapter.
:thinking:
JLuigi
Many thanks for all your help - it still does not work, so I have sent for a cheap external USB card adapter.
Regards
JL
