Hi!
I've a little problem with FlashMedia SD/MMC, I can't see the icon on my computer like this image: (NOT THE MEMORY STICK BUT SD ON THE RIGHT)
Is there a way to fix this?
Thx!
Go into your device manager by rightclick computer>properties>device manager and the forth icon down is disk drives. Open the tree and you should find your sd1 device. Try reinstalling it by deleting it and then rebooting and enable -- disable. If the icon is not there then try a system restore to a time when it worked.
Ok I will try, the "problem" is that I perform a clean installation on Vista and I don't want to restore by recovery dvd.
I installed:
Memory Card Reader Writer Driver Richoh MS -
114.97 kb 23/10/2008
Memory Card Reader Writer Driver Ricoh SD -
29.73 kb 15/01/2009
Memory Card Reader Writer Driver Ricoh SD CPRM -
62.53 kb 29/07/2008
But there is only MEMORY STICK icons...
