The fan problem for the vaio, does that only happen to the bigger laptops, like the 15", or does it happen with all the laptops? Thanks for your help!
You should find where the fan is located where there are vent openings in the laptop. Normally they would have a black or metal covering. The common location would be in the back corners of the laptop.
Clean it with a light suction vaccume hose, and with cotton-swabs on the fan blades to loosen any dust or foreign matter.
If you're still encountering the same problem, it's best to get that checked by someone or a company who does laptop repairs.
_______________
Life is too serious to be taken seriously
Copy/pasted from http://answers.yahoo.com/question/index?qid=20110801083424AAzkOTx
Message was edited by: rich912
To provide source of copy/pasted answer from another forum.
