Sony VAIO SVE1511S1ESI
profile.country.ro_RO.title
Nica.Gabriel
Hello ,
I recently bought a Sony VAIO laptop SVE1511S1ESI, I formatted the HDD, and now I want to install all programs, as with all programs that come preinstalled.
Can someone help me ?
6 REPLIES 6
rich912
Hi Nica.Gabriel,
The original utilities and drivers can be downloaded from the Support site.
http://www.sony.co.uk/support/en/product/SVE1511S1ESI/updates
Most of the original software is not available for download due to licencing agreements.
You haven't said why you formatted the drive but if your recovery partition is intact you could recover to factory settings by tapping F10 at boot to access the recovery utility or if you created the recovery disks use these. This will reinstate all of the pre-installed software.
Rich
Go n-éirí an bóthar leat
Nica.Gabriel
so there is no way to restor to ... first use (factory settings ) if i formated the HDD?
rich912
I assume from your reply that you didn't create your recovery disks - have you tried tapping F10 at boot to access the recovery utility?
If neither of these options are available to you then you can order a set of recovery media from Support - there is a charge of course...
Rich
Nica.Gabriel
can u post a link ? i can't find it
rich912
http://www.sony.co.uk/support/en/contacts
For Romania try here: -
http://www.sony.ro/support/ro/contacts
Click on 'Vaio and Computing' and enter your Vaio's Serial Number.
:wink:
